[Gdal-dev] setup GDAL : from GDAL source or FWTools?
Eduardo Patto Kanegae
epk.lists at gmail.com
Fri Oct 27 10:28:47 EDT 2006
hi folks,
I setup GDAL 1.3.2 on Fedora5 againts external libraries such as ECW SDK,
GeoExpress(MrSID) SDK, OCI and others.
I did it using standard --prefix=/usr/local/lib , and I'd like to know if I
set FWTools 1.0.6 on this same machine
it will or not conflict with already existing GDAL installation.
Or should uninstall GDAL and only install FWTools?
thanks
http://www.webmapit.com.br
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20061027/3abcaf2e/attachment.html
