[Gdal-dev] SDE Driver Change
Craig Miller
craig.miller at spatialminds.com
Fri Oct 27 10:46:04 EDT 2006
An IsHole() could certainly be added to GDAL or implemented stand-alone
(GEOS?) fairly easily following just that approach. Start outside the
outermost polygon and draw a line through the polygon. Cross 1 line (odd)
you are in the polygon, cross another (even) you are in a hole (or outside
again), another line (odd) inside the polygon, another (even) in a hole (or
outside again), etc.
--Craig
-----Original Message-----
[mailto:gdal-dev-bounces at lists.maptools.org] On Behalf Of Bill Thoen
Sent: Friday, October 27, 2006 7:10 AM
To: Christian Ratliff
Cc: gdal-dev at lists.maptools.org
Subject: Re: [Gdal-dev] SDE Driver Change
Watch out for MIF and TAB files... In MapInfo formats there are no enforced
associations between interior rings ordered deosil or widdershins (or
clockwise/counterclockwise) and whether they are holes or contours/islands.
In fact, the first ring isn't necessarily the exterior ring either (although
it usually is). I think MapInfo uses some sort of a border crossing
algorithm to determine what's a hole and what's a part of the region
(multipolygon). They definitely don't rely on ring point ordering.
- Bill Thoen
On Fri, Oct 27, 2006 at 08:47:13AM -0400, Christian Ratliff wrote:
> Perhaps you can help me figure out this puzzle. In a multi-polygon,
> from what I can find, the OGRLinearRing::isClockwise() function is the
> way to determine if a ring is a contour (clockwise) or a hole
> (counter-clockwise). When reading GML, MIF, TAB and SHP if
> isClockwise() is true then the ring is a contour, otherwise it is a
> hole. However, when reading from ARC/SDE the behavior was opposite.
> I would rather avoid encoding knowledge of the data source in to the
> OGR geometry processor code, up in my application. Except for that
> option, how is one to determine the implication of isClockwise() or
> perhaps I totally flubbed and missed a 'isHole()' method somewhere?
> Thanks!
> christian
> From: Frank Warmerdam [mailto:warmerdam at pobox.com]
> Sent: Thursday, October 26, 2006 2:15 PM
> > During the QA process for our product, we noticed polygons were
> > being read from ARC/SDE with a reversed (left hand) winding. This
> > results in
> > isClockwise() returning the wrong value for all such polygons. I
> > updated the SDE driver with the change indicated below and then
> > re-tested SDE and non-SDE data sources. Everything looks good now:
> > src/ogr/ogrsf_formats/sde/ogrsdelayer.cpp
> > 719c723
> > < nSDEErr = SE_shape_get_all_points( hShape, SE_DEFAULT_ROTATION,
> >> SE_RIGHT_HAND_ROTATION,
> Christian,
> There is no harm in doing this, but I would note that OGRPolygon rings
> are not guaranteed to have any particular handedness. So it is unwise
> to build application on this assumption.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam,
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | President OSGeo,
> http://osgeo.org
> Gdal-dev mailing list
> Gdal-dev at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/gdal-dev
