[Gdal-dev] gdal_merge.py failed for ENVI format
Nicolas Ribot
nicky666 at gmail.com
Tue Oct 31 13:52:13 EST 2006
> The gdal_merge script loads the entire source image into RAM so
> if your source images are large it will generally fail. It may or
> may not properly report the out of memory condition.
Complete image is about 6 Gb, and I have 1 Gb of RAM...
> I vaguely recall some odd issue with fat32 bit partitions and
> large files on win32, but I don't think this will be affecting
> things on linux. I gather the output is being written to an ext2
> partition?
Yes it is.
> BTW, the solution is to use gdalwarp to merge the datasets as mentioned
> in another recent post here (or perhaps on fwtools mailing list?).
I will search the lists for this post.
Thanx a lot.
