[Gdal-dev] ogr2ogr Unable to open datasource
Ryan Ollerenshaw
ollerery at engr.orst.edu
Tue Oct 31 13:54:17 EST 2006
Ryan Ollerenshaw wrote:
>> Because as far as OGR knows the csv file is non-spatial, so when it
>> creates
>> the "shapefile" it just creates the .dbf file and no spatial files.
>> If you want to treat the first two columns as a point location you
>> need to
>> follow extra steps (ie. using an OGR VRT file) to turn them into a
>> spatial
>> location.
>> Best regards,
> Thank you for the help but the documentation for using an OGR VRT file
> does not seem to be clear. I created a ovf file (see below) and ran
> # ogr2ogr -f "ESRI Shapefile" thick18.shp thick18.cvs
> but still no change only a dbf file is created. I do not see in the
> VRT documentation how to use the ovf file.
> Resources I have found:
> http://gdal.maptools.org/ogr/drv_vrt.html
> http://mapserver.gis.umn.edu/docs/reference/vector_data/VirtualSpatialData
ovf file:
<OGRVRTDataSource>
<OGRVRTLayer name="thick18">
<SrcDataSource>thick18</SrcDataSource>
<SrcLayer>thick18.csv</SrcLayer>
<GeometryField encoding="PointFromColumns" x="long" y="lat"/>
<GeometryType>wkbPoint</GeometryType>
</OGRVRTLayer>
</OGRVRTDataSource>
csv file:
lat,long,water_thic,error
-180, 90.00, 0.00, 4.84
-179, 90.00, 0.00, 4.84
-178, 90.00, 0.00, 4.84
-177, 90.00, 0.00, 4.84
-176, 90.00, 0.00, 4.84
-175, 90.00, 0.00, 4.84
-174, 90.00, 0.00, 4.84
> -Ryan
> Gdal-dev mailing list
> Gdal-dev at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/gdal-dev
