[Gdal-dev] COmpliler errors in GDAL 1.3.2 on windows with VC6
Mateusz Loskot
mateusz at loskot.net
Tue Oct 31 17:26:13 EST 2006
Zuyuan Wang wrote:
> Hello, there,
> I am a newer to GDAL. I have already updated the two files :
> IdrisiDataset.cpp, and cpl_odbc.cpp. as the instruction as
> http://lists.maptools.org/pipermail/gdal-dev/2006-May/008789.html
> But when I used VC6 on windows to compile GDAL 1.3.2 again , I still
> got the following error info:
> cpl_odbc.cpp
> cpl_odbc.cpp(412) : error C2440: '=' : cannot convert from 'int *' to
> 'long *'
> Types pointed to are unrelated; conversion requires
> reinterpret_cast, C-
> style cast or function-style cast
> NMAKE : fatal error U1077: 'cl' : return code '0x2'
> Stop.
> NMAKE : fatal error U1077: '"C:\Program Files\Microsoft Visual
> Studio\VC98\bin\N
> MAKE.EXE"' : return code '0x2'
> Stop.
> Any suggestion will be grateful!
Zuyuan,
Are you sure you've updated cpl_odbc.cpp but not cpl_odbc.h ?
In the link with solution you pasted above directs to cpl_odbc.h:
http://www.gdal.org/srctree/port/cpl_odbc.h
but
it should point to
http://www.gdal.org/srctree/port/cpl_odbc.cpp
So, please check it and try to compile again.
Cheers
Mateusz Loskot
http://mateusz.loskot.net
