[Gdal-dev] Re: Memory leak under Matlab (a follow up from -
importFromWkt() problem)
Joaquim Luis
jluis at ualg.pt
Mon Sep 4 12:50:40 EDT 2006
Mateusz,
> May be you're using mexMakeMemoryPersistent in loop or similar call,
> so memory is not cleared after your MEX is unloaded.
Sorry, I forgot to comment this.
MEXs are never unloaded (unless we issue a 'clear' command) so, for
example, global variables
retains their values between successive mex calls.
This is a comprehensible behavior since loading a mex takes some time
and imagine how slow
a loop would be if inside it the dll had to loaded in every loop step.
Does this ring any bells for anything that are normally cleared by the
system at the execution end
but will not be done here?
Joaquim
