[Gdal-dev] python gdal 1.3.2 and geos
Christopher Barker Chris.Barker at noaa.gov
Tue Sep 5 12:38:41 EDT 2006
Didrik Pinte wrote:
> Because of a problem between gdalnumeric and python-numpy, I have
> uninstalled the following packages and kept only python-numeric :
> apt-get remove python-numpy python-numpy-ext python-scipy fftw3
> It solved the problem ! That's strange.
That is very odd. the new numpy and the old Numeric should have no
trouble at all co-existing.
My guess is that it is a Debian bug -- perhaps the python-numpy package
is set up to replace Numeric, rather than coexist with it. However, if
not, then there may be a bug in numpy, and it should be reported. It is
certainly intended that they don't interfere with one another.
-Chris
Christopher Barker, Ph.D.
Oceanographer
NOAA/OR&R/HAZMAT         (206) 526-6959   voice
7600 Sand Point Way NE   (206) 526-6329   fax
Seattle, WA  98115       (206) 526-6317   main reception
