[Gdal-dev] GDAL and Solaris 10/sparc
Jingmu Yang
jingmuyang at aol.com
Thu Sep 7 13:46:28 EDT 2006
I used the following configuration to successfully build GDAL 1.3.2 on
Solaris 10 with gcc 3.4.3 under /usr/sfw/bin/.
./configure --with-png=internal --with-jpeg=internal --with-geotiff=internal
--with-libtiff=internal --with-libz=internal --with-unix-stdio-64=no
--with-static-proj4=/usr/local/lib
Jingmu
Shaun Kolomeitz wrote:
> After months of searching, hacking and many hundreds of compile attempts I
> am still unable to successfully get GDAL to compile on a SPARC/Solaris 10
> environment. No amount of searching lists and getting obscure possible
> fixes has worked.
> My original aim was to get GDAL with ECW compiled and going, but for now
> I'd even settle for just Geotiff, HFA and JPEG. I'll just have to use
> WindoZe to do any other conversions.
> Would someone mind sending me some settings from their working GDAL
> sparc/Solaris X configurations ?
> Stuff like the system wide "crle", PATH and LD_LIBRARY_PATH settings for
> compilation and the versions of GCC/etc that actually work.
> Any other suggestions that might help me get this going would be most
> welcome.
> TIA,
> Shaun
> ___________________________
> Disclaimer
> This e-mail, including attachments if any, has originated from a
> Queensland government agency and may contain information that is
> confidential, or covered by legal professional privilege, and is intended
> for the named recipient(s) only. If you have received this message in
> error, you are asked to inform the sender as quickly as possible and
> delete this message and any copies of this message from your computer
> system network.
> Any form of disclosure, modification, distribution and/or publication of
> this e-mail, including attachments is prohibited. Unless otherwise
> stated, this e-mail, including attachments represents the views of the
> sender and not the views of the Environmental Protection Agency.
> Although this e-mail has been checked for the presence of computer
> viruses, the Environmental Protection Agency provides no warranty that all
> possible viruses have been detected and cleaned. Any use of this e-mail
> could harm your computer system.
> Gdal-dev mailing list
> Gdal-dev at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/gdal-dev
View this message in context: http://www.nabble.com/GDAL-and-Solaris-10-sparc-tf2149918.html#a6195088
Sent from the GDAL - Dev forum at Nabble.com.
