[Gdal-dev] GDAL and Solaris 10/sparc
Jingmu Yang jingmuyang at aol.com
Fri Sep 8 09:24:24 EDT 2006
The reason why I used option --with-unix-stdio-64=no in configuration is that
I experienced compiling error.  After I added that option the build went
through.  My goal is just to build the library successfully.
Regards,
Jingmu
Martin Spott wrote:
> Hi Jingmu,
> Jingmu Yang wrote:
>> I used the following configuration to successfully build GDAL 1.3.2 on
>> Solaris 10 with gcc 3.4.3 under /usr/sfw/bin/.
>> ./configure --with-png=internal --with-jpeg=internal
>> --with-geotiff=internal
>> --with-libtiff=internal --with-libz=internal --with-unix-stdio-64=no
> I'm very curious to know which goals you achieve with this option.
> Thanks,
> 	Martin.
>  Unix _IS_ user friendly - it's just selective about who its friends are !
> Gdal-dev mailing list
> Gdal-dev at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/gdal-dev
View this message in context: http://www.nabble.com/GDAL-and-Solaris-10-sparc-tf2149918.html#a6208832
Sent from the GDAL - Dev forum at Nabble.com.
