[Gdal-dev] Wide-character filenames with GDAL file IO?
Ben Discoe
ben at vterrain.org
Sun Sep 10 04:42:30 EDT 2006
Frank,
I'm still interested to see what you think of the previous email, but i did
one test:
I split CSLLoad into two methods: the first takes a (const char *)
filename, the other takes a (FILE *). The first just calls VSIFOpenL and
calls the second. That opens the possibility of the user to pass their own
(FILE *) into the second. However, it doesn't work.
Apparently, as the documentation for VSIFOpenL says, "the FILE * returned by
this function is not really a standard C library FILE *, and cannot be used
with any functions other than the VSI*L family of functions." The converse
appears true as well, you cannot use regular FILE* with the VSI family of
functions.
Hence, it seems our uptions are limited to the following:
1. Provide a second entry point for each GDAL function taking a (const char
*filename), which takes a (const wchar_t *filename).
2. Leave the entry points the same, but declare that all non-ASCII filenames
passed to GDAL must be UTF-8. This would have no effect on existing code
using ASCII filename, and no effect on existing code on OSX. Inside
VSIFOpenL or similar, we would need code like this:
FILE *VSIFOpenL( const char * pszFilename, ...)
#if WIN32
(convert pszFilename from utf-8 to wide string)
use _wfopen(wide string);
#elif __DARWIN_OSX__
(proceed normally, it already expects utf-8)
#else
// some other flavor of Unix
(convert pszFilename from utf-8 to wide string to local code page, using
ANSI wctombs())
use fopen(local string);
#endif
3. Do the above, but make the methods which take UTF-8 into a separate set
of entry points. That makes it 100% sure not to break anyone's existing
code, which might be currently passing in non-ASCII characters.
Thoughts? I can help do the implementation work, as i am now feeling fairly
well grounded in cross-platform charset issues.
Thanks,
Ben
_____
Sent: Saturday, September 09, 2006 2:32 PM
To: gdal-dev at lists.maptools.org
Subject: RE: [Gdal-dev] Wide-character filenames with GDAL file IO?
> > Then i could pass the fd into GDAL, if it had a way of accepting it.
> There is no support for this in GDAL.
That might be a (relatively) painless solution then - for a the few places
in GDAL that take a (const char *) filename, a second entry point that take
a (FILE *). I will explore this option, but you may already understand the
ramifications better?
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20060909/55c407e4/attachment.html
