[Gdal-dev] Memory leak under Matlab (a follow up from -
importFromWkt() problem)
Joaquim Luis
jluis at ualg.pt
Mon Sep 11 16:40:09 EDT 2006
Philip Borghesani wrote:
> It is not always simple or straight forward to translate from a properly
> working main to a mex function. In the example code you supplied I am
> concerned about some of the initialization code that the tested example you
> linked to is not doing in a while loop.
> Remember that a mex file is not unloaded after each call so you code is
> doing the equvilent of putting a loop around a main function.
> Try placeing the initiization code in a block that will only run once:
> // untested code
> static OGRSFDriver *poDriver = NULL;
> if (poDriver==NULL) {
> OGRRegisterAll();
> // Driver
> poDriver
> =OGRSFDriverRegistrar::GetRegistrar()->GetDriverByName(pszDriverName);
> assert(NULL != poDriver);
> // I do not see any code that deletes or releases the poDriver is this
> needed
I received the mail above from the Mathworks.
I did what Philip Borghesani suggested without any advance. That is the
memory leak still leaks.
However, I would like to be 100% sure in the answer to the second question.
Is the poDriver automatically freed?
Thanks
Joaquim Luis
