[Gdal-dev] installation problem gdal-1.3.2
Murat BEYHAN
beyhan at deprem.gov.tr
Wed Sep 13 07:13:13 EDT 2006
Hi friends,
I would like to use OGR/Mapserver/Mysql functionality to create a map by using
data stored in Mysql.
For this Actually I couldn't understood more about Ogr but
I would like to install gdal-1.3.2 bur I always facing following error message.
I really have spent a lot of time to solve this problem but I couldn't achieved.
Please if anybody has idea about the mistake which I did,
tell me.
Just I'm asking you.
Is it possible to read data for example point data for the location of city
from MySQL database tables to draw it on the map without creation shp files or
OGR can create shape files for drawing the map.
Thank you...
result of my installation stages are here.
configure --with-mysql --with-netcdf
GDAL is now configured for i686-pc-linux-gnu
Installation directory: /usr/local
C compiler: gcc -O2
C++ compiler: g++ -O2
LIBTOOL support: yes
LIBZ support: external
GRASS support: libgrass
CFITSIO support: no
PCRaster support: internal
NETCDF support: yes
LIBPNG support: external
LIBTIFF support: external
LIBGEOTIFF support: internal
LIBJPEG support: external
LIBGIF support: internal
OGDI support: yes
HDF4 support: no
HDF5 support: no
KAKADU support: no
JASPER support: no
ECW support: no
MrSID support: no
POSTGRESQL support: no
MySQL support: yes
XERCES support: no
ODBC support: no
OCI support: no
SDE support: no
DODS support: no
SQLite support: no
DWGdirect support no
PANORAMA GIS support: no
GEOS support: yes
Statically link PROJ.4: no
Traditional Python: no
NG SWIG Bindings:
enable OGR building: yes
make
after run make the last two lines are here
creating gdal_rasterize
make[1]: Leaving directory `/usr/local/gdal-1.3.2/apps'
make install
after run make install the last four lines are here
make[1]: Leaving directory `/usr/local/gdal-1.3.2/man'
for f in data/*.* ; do /usr/local/gdal-1.3.2/install-sh -c -m 0644 $f
/usr/local/share/gdal ; done
/bin/sh /usr/local/gdal-1.3.2/libtool --mode=finish --silent /usr/local/lib
ldconfig: /usr/local/lib/libpdf.so.5 is not a symbolic link
after this
I would like to try ogrinfo ond ogr2ogr commands
But I have faced the following error
[root at sakura gdal-1.3.2]# ogrinfo
ogrinfo: error while loading shared libraries: libgdal.so.1: cannot open
shared object file: No such file or directory
what is wrong which I did...
Thank you
This message has been scanned for viruses and
dangerous content by MailScanner, and is
believed to be clean.
