[Gdal-dev] Default Settings when Compiling GDAL
Mateusz Loskot mateusz at loskot.net
Tue Sep 19 13:27:30 EDT 2006
Bill Thoen wrote:
> If I compile the GDAL package using just the defaults, is support for
> postgres one of the defaults or do I need to add the --with-pg option?
AFAIK yes.
If you run only ./configure without any PostgreSQL related options,
the ./configure script will *try* to detect it and if found,
it will turn the PG support on.
> How do I tell which options are set "on" by default?
You can always try-and-see :-)
Some of default values of options are listed after you run:
./configure --help
I don't know any better way.
Cheers
Mateusz Loskot
http://mateusz.loskot.net
