[Gdal-dev] Wide-character filenames with GDAL file IO?
Ben Discoe ben at vterrain.org
Tue Sep 19 17:33:40 EDT 2006
> From:Andrey Kiselev
> Sent: Monday, September 11, 2006 1:06 AM
> I think the simplest way to add multibyte support to GDAL is
> using UTF-8 as an internal character set. All strings and
> filenames should be passed in UTF-8 encoding and properly
> converted to UCS-16 when needed (_wopen on Windows).
I agree this seems like a workable solution.
> The major drawback of this change is additional
> requirement: we will need an Unicode library to replace all
> string handling functions from the C lib with the Unicode aware ones.
Not necessarily.  This really only affects filepath/filename strings.  Since
UTF-8 and ASCII are identical over the range of ASCII, and string subsets
which GDAL could conceivably need to manipulate such as file extentions
("*.tif") are ASCII, nothing breaks by declaring that all filenames passed
to GDAL must be UTF-8.
I have found this to be true with the entire VTP software, which sits above
GDAL.  It now uses UTF-8 internally for all filesystem strings, and has not
encountered the need for any special Unicode library.
> This problem was raised one time in the past, probably this
> is a time when we should prepare RFC for GDAL localization.
> This is a major change, this change can broke functionality,
> so it is painful, but inevitable.
I suspect is not so major.  I'm willing to tackle the task, if Frank et al.
are interested.
-Ben
