[Gdal-dev] Wide-character filenames with GDAL file IO?
Ben Discoe
ben at vterrain.org
Thu Sep 21 02:07:38 EDT 2006
Mateusz,
> >>> MSDN documents that there is a
> >>> (wchar_t*) version of std::ifstream() constructor
> >>> (http://msdn2.microsoft.com/en-us/library/zek0beca.aspx),
> Now, everything is clear. We're talking about two different
> things, but that's because I've had no idea about this ctor.
> And because the problem is in the MSDN documentation :-)
Yes. :)
> second constructor you see, that takes const wchar_t*
> parameter is a non-standard *extension* introduced by Microsoft.
Well sure. So is _wfopen, and _wfopen is great.
The trouble here is not that it's a non-standard *extension*, but that it's
a non-standard *extension* which appears in the docs but not in the product.
> That's why you can't find it in the MSVC++ 7.1
Well no, MSVC++ 7.1 has all of Microsoft's nonstandard extension, except
(apparently) this one.
> Because, what I'm expalining above, there is no wide-char
> based ctor in basic_ifstream class, according to the C++ standard.
Yes, it's well known that the C and C++ standards are critically flawed in
that they only support a local charset, not unicode. This discussion isn't
about standards, but about how we can implement support for all filenames in
GDAL. Fortunately for GDAL, it (apparently) sticks to C stdlib, so we can
(thankfully) use _wfopen on Windows.
-Ben
