[Gdal-dev] Wide-character filenames with GDAL file IO?
Mateusz Loskot
mateusz at loskot.net
Thu Sep 21 04:04:25 EDT 2006
Ben Discoe wrote:
>> If there are Unicode and non-Unicode versions of CPL, then
>> may be it could be possible to build GDAL in Unicode mode on request.
>> It should simplify maintenance of the GDAL codebase.
> Since we plan to use UTF-8, instead of wide strings, then it is not
> necessary to built GDAL in different modes. That is indeed simpler.
OK, it's clear.
Cheers
Mateusz Loskot
http://mateusz.loskot.net
