[Gdal-dev] Wide-character filenames with GDAL file IO?
Thu Sep 21 10:55:05 EDT 2006
Ben Discoe wrote:
> Andrey,
>> -----Original Message-----
>> From: Andrey Kiselev
>> Sent: Tuesday, September 19, 2006 11:05 PM
>> My concern is not only a file names, but the Unicode support
>> for all GDAL/OGR strings.  Personally I would like to see
>> localized field names in OGR and localized metadata in GDAL.
> I can't imagine how other GDAL/OGR would need to do charset manipulation?
> As long as the user gives UTF-8 or other 1-byte strings, GDAL/OGR can be
> charset agnostic.  It isn't doing any charset handling now for
> non-filenames, and it works just fine.  But, we can keep an eye out for
> this, should it turn up.
Ben / Andrey,
Perhaps we should look at doing a first pass implementation only for
filenames, and then look at other strings (metadata, descriptions,
OGR field values and field names) as a second pass if filenames
are where most of the benefit is.
>> But the filename issue is a good starting point.
>> I think it should be done in the following steps:
>> 1. Pick up the Unicode implementation.
>> 2. Implement appropriate CPL layer for Unicode strings.
>> 3. Convert all related CPL functions to use this new CPL
>> layer.
> I am happy to do this work and submit it, i am just waiting to hear from you
> (or Frank, or..? Confused by GDAL's new democracy) that i should proceed.
GDAL's new democracy is covered in:
   http://www.gdal.org/rfc1_pmc.html
Briefly, a disruptive change such as the UTF-8 upgrade needs to be
written up as a formal proposal to the PSC, and voted on after discussion.
I think I would like to see a 1.3.3 release before we start incorporating
UTF-8 support, and at that point we would likely consider the UTF-8 work
to be towards GDAL 1.4.0.
>> Note, that filenames often embedded in more complex
>> structures , so we should be sure that all functions,
>> responsible for parsing or serialization, work correct with
>> UTF-8 strings.
> Agreed.
Good point.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
