[Gdal-dev] RFC DRAFT: Unicode support in GDAL
Mateusz Loskot mateusz at loskot.net
Thu Sep 21 15:00:46 EDT 2006
Mateusz Loskot wrote:
> May be we could try to compose a list of formats that are
> Unicode-friendly and on what conditions. What do you think?
I checked if ArcGIS handles Unicode in Shapefile and it seems it's
officially supported, though I'm not the ArcGIS user but I've only read
its manual.
Also, ArcSDE provide some/limited Unicode support.
ESRI Personal Geodatabase supports Unicode well.
Here is a bunch of URLs:
FAQ: Does ArcGIS Desktop support Unicode?
<http://support.esri.com/index.cfm?fa=knowledgebase.techarticles.articleShow&d=27345>
ArcSDE geodatabases have limited support for Unicode.
<http://support.esri.com/index.cfm?fa=knowledgebase.techarticles.articleShow&d=27341>
HOWTO:  Read and write Shapefile and dBASE file encoded in various
code pages
<http://support.esri.com/index.cfm?fa=knowledgebase.techarticles.articleShow&d=21106>
Interesting quotes:
"Note: You can now store Shapefile in UTF-8. However, Shapefile encoded
in UTF-8 will only be recognized in ArcGIS Desktop."
I'm not sure how to understand this quote, but I also believe
every client software that works with Shapefile format is free to
support Unicode in Shapefile files, isn't it?
Cheers
Mateusz Loskot
http://mateusz.loskot.net
