[Gdal-dev] RFC DRAFT: Unicode support in GDAL
Armin Burger armin.burger at gmx.net
Thu Sep 21 17:21:22 EDT 2006
When I remeber well, you have to specify globally in the Windows
registry if the .dbf of shapefiles are encoded in UTF. But if you do so
and then load a shapefile not in UTF then the special characters are
displayed wrong.
So ArcGIS has not really a flexible support for UTF, at least not for
shapes.
armin
Frank Warmerdam wrote:
> Mateusz Loskot wrote:
>> Interesting quotes:
>> "Note: You can now store Shapefile in UTF-8. However, Shapefile encoded
>> in UTF-8 will only be recognized in ArcGIS Desktop."
>> I'm not sure how to understand this quote, but I also believe
>> every client software that works with Shapefile format is free to
>> support Unicode in Shapefile files, isn't it?
> Mateusz,
> I presume the above note is because there is no "standard" way of
> indicating
> that text in a .dbf file is in UTF-8.  I persume ArcGIS is using some
> custom
> flag to keep track of this.  If we can figure out what they did, we could
> also honour it.
> Best regards,
