[Gdal-dev] Loosing positions in S-57 to S-57 conversion via ogr2ogr
Thu Sep 28 09:25:10 EDT 2006
Jean-Philippe RANNOU wrote:
> Hi,
> I'm trying to use S-57 to S-57 conversion via OGR.
> I set the minimum required options (specified in OGR S-57 html doc)
> set OGR_S57_OPTIONS =
> "RETURN_PRIMITIVES=ON,RETURN_LINKAGES=ON,LNAM_REFS=ON"
> I checked WRECKS positions in my S-57 file using
> ogrinfo CA49995B.000 WRECKS
> I did the conversion for WRECKS
> ogr2ogr -skipfailure -append -f "S57" output.000 CA49995B.000 WRECKS
> but in the resulting file when i check the resulting file
> ogrinfo output.000 WRECKS
> and the WRECKS positions disapeared (no more POINTS and empty polygons).
> Has somebody experienced such conversion? What am i doing wrong?
JP,
I just tried a similar conversion and it worked for me.  The resulting
S-57 file did have wrecks.  I did observe that the new DSID feature class
support is not supported by the writer.
Are you confident that the double quotes did not get included in your
OGR_S57_OPTIONS senvironment variable?  Does an ogrinfo on your original
file show layers called IsolatedNode, ConnectedNode, Edge and Face (as
well as the regular feature classes)?
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
