[Gdal-dev] GDAL coordinate reference system retrieval problems.
Daniele Romagnoli
dany.geotools at gmail.com
Fri Sep 29 08:52:15 EDT 2006
Hi list,
I have some problems during coordinate reference system retrieval operations
with GDAL.
Using gdalinfo or directly using "Dataset.GetProjection()" on some files, it
returns the empty string "" while,
using gdalinfo from FWTools, it returns the required projection string.
Any suggestion? (DLL, required library,...)?
Thank you very much.
Best Regards,
Daniele
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20060929/04458cd6/attachment.html
