[Gdal-dev] Make error "libtool: compile: unable to infer tagged
configuration"
Alessandro Amici
lists at b-open-solutions.it
Sun Apr 1 05:58:52 EDT 2007
Eric,
On Friday 30 March 2007 17:54, Patton, Eric wrote:
> I just upgraded my Ubuntu to 7.04 Beta, and I'm re-compiling gdal-1.4.0.
> configure progresses cleanly with no obvious errors. At the very beginning
> of make, however, I encounter this error:
> $ sudo make
> (cd port; make)
> make[1]: Entering directory `/usr/local/gdal-1.4.0/port'
> /bin/sh /usr/local/gdal-1.4.0/libtool --mode=compile g++ -DOGR_ENABLED
> -I/usr/local/gdal-1.4.0/port -c -o cpl_conv.o cpl_conv.cpp libtool:
> compile: unable to infer tagged configuration
> libtool: compile: specify a tag with `--tag'
> make[1]: *** [cpl_conv.o] Error 1
> make[1]: Leaving directory `/usr/local/gdal-1.4.0/port'
> make: *** [port-target] Error 2
i just tried a clean configure/make with gdal 1.4.0 on ubuntu 7.04 beta
(x86_64 in my case) and i can't reproduce the problem.
> Any ideas on what this error means and how to correct it?
be sure to run 'make distclean' before configure (if you aren't already) or
better start from a fresh tree.
please report the result, thanks.
cheers,
alessandro
B-Open Solutions srl -- http://www.bopen.it/
