[Gdal-dev] IdrisiDataset::SetGeoTransform
Ari Jolma
ari.jolma at tkk.fi
Sun Apr 1 10:45:04 EDT 2007
There's been an error long time (the only error) in the Perl bindings
autotest because of IdrisiDataset::SetGeoTransform and a subsequent
IdrisiDataset::GetGeoTransform failing to produce identical
transformation. I thought I had reported it on the this list or as a
bug, but can't find it anywhere.
My question is should the IdrisiDataset::SetGeoTransform modify
adfGeoTransform, from which is reported in GetGeoTransform? If not, then
I can just skip that test, if yes, then that's probably a bug?
Then, I see the buildbot is running a csharp-test. Maybe it would be a
good idea to run the Perl-bindings test?
Regards,
Ari
