[Gdal-dev] IdrisiDataset::SetGeoTransform
Frank Warmerdam
warmerdam at pobox.com
Sun Apr 1 11:41:21 EDT 2007
Ari Jolma wrote:
> There's been an error long time (the only error) in the Perl bindings
> autotest because of IdrisiDataset::SetGeoTransform and a subsequent
> IdrisiDataset::GetGeoTransform failing to produce identical
> transformation. I thought I had reported it on the this list or as a
> bug, but can't find it anywhere.
> My question is should the IdrisiDataset::SetGeoTransform modify
> adfGeoTransform, from which is reported in GetGeoTransform? If not, then
> I can just skip that test, if yes, then that's probably a bug?
Ari,
If you file this as a bug, I will turn it over to Ivan to investigate.
> Then, I see the buildbot is running a csharp-test. Maybe it would be a
> good idea to run the Perl-bindings test?
> Regards,
I see Mateusz is on top of this issue.
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
