[Gdal-dev] Perl bindings added to the Buildbot
Frank Warmerdam
warmerdam at pobox.com
Sun Apr 1 13:25:28 EDT 2007
Ari Jolma wrote:
> Mateusz Loskot wrote:
>> Currently, SWIG C# uses "make interface", Perl uses "make generate"...
>> I think it's a good idea to unify these targets,
>> according to the idea of "learn once, use everywhere".
> Ideally it should test if the wrappers are older than the interface
> files and "make" would be all that we need.
Ari,
I believe that the generate step is explicit to avoid folks accidentally
corrupting their generated files if they have the wrong version of swig
installed. So, all things considered, I'd rather not have the makefiles
automatically run generate.
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
