[Gdal-dev] Tansverse Mercator South Oriented question
Zindine nabble at souiki.org
Mon Apr 2 14:44:55 EDT 2007
I have the PROJCS below defined and it does not get validated by OGR.
I receive the error: OGRERR_UNSUPPORTED_SRS.
It was simply defined as follow:
        OGRSpatialReference    oTMSO;
        oTMSO.SetProjCS("TMSO Zone 29 / WGS84");
        oTMSO.SetWellKnownGeogCS( "WGS84" );
        oTMSO.SetTMSO(0,29,1,0,0);
Can anyone help me find the error? Thanks.
PROJCS[
                "unnamed"
                ,GEOGCS[
                        "WGS 84"
                        ,DATUM[
                                "WGS_1984"
                                ,SPHEROID["WGS
84",6378137,298.257223563,AUTHORITY["EPSG","7030"]]
                                ,TOWGS84[0,0,0,0,0,0,0]
                                ,AUTHORITY["EPSG","6326"]
                        ,PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]]
,UNIT["degree",0.0174532925199433,AUTHORITY["EPSG","9108"]]
                        ,AXIS["Lat",NORTH]
                        ,AXIS["Long",EAST]
                        ,AUTHORITY["EPSG","4326"]
                ,PROJECTION["Transverse_Mercator_South_Orientated"]
                ,PARAMETER["latitude_of_origin",0]
                ,PARAMETER["central_meridian",29]
                ,PARAMETER["scale_factor",1]
                ,PARAMETER["false_easting",0]
                ,PARAMETER["false_northing",0]
View this message in context: http://www.nabble.com/Tansverse-Mercator-South-Oriented-question-tf3507502.html#a9796511
Sent from the GDAL - Dev mailing list archive at Nabble.com.
