[Gdal-dev] Bool vs int in bindings?
Simon Perkins
sy at perkins.net
Tue Apr 3 12:40:55 EDT 2007
Hi Howard and Tamas,
Thanks for putting me straight on this. You've convinced me!
I shall suppress my overdeveloped aesthetic sense and continue to be
grateful that I can use the splendid GDAL library with C# so easily...
Cheers!
Sy
Howard Butler wrote:
> Simon,
> Regarding the booleans, I am pretty strongly against this idea because
> it would mean a lot of divergent maintenance for languages that
> *don't* support boolean types, and GDAL itself uses ints which would
> mean we would have to have language-specific coercion. It seems like
> a lot of pain for little benefit.
> Regarding renaming, I'm ok with proper namespaces and using enums, but
> language-specific renames to follow its language conventions seems
> like a road to hell paved with good intentions. I agree that
> GDAL/OGR's swig bindings are indeed rough in some places and are often
> not ideal as far as ease of use and following the norms of all of the
> languages it supports. In my opinion, the purpose of the swig
> bindings is not to provide an ideal development library for geographic
> data manipulation in every language supported -- instead its purpose
> is to provide *access* to the GDAL/OGR/OSR facilities in as many
> languages as possible. This means compromise in a number of areas,
> with naming conventions, calling conventions, and many language norms
> being some of them.
> One approach you might take if you are wishing to smooth over the
> rough spots of the swig bindings in your language is to develop a
> wrapper library. For example, the Python Cartographic Library
> provides a more unified approach to data access, including GDAL/OGR
> through wrapping the swig API, and it more closely follows Python's
> language norms in the process.
> SWIG^H^H^H^Hcompromise-is-the-art-of-spreading-misery-ly y'rs*
> Howard
> *<http://www.amk.ca/quotations/python-quotes/page-10>
> On Apr 3, 2007, at 12:01 AM, Simon Perkins wrote:
>> Hi,
>> A lot of the SWIG generated binding functions use ints as arguments
>> and return types when a boolean type would be more appropriate, e.g.
>> the OGR Open() method takes an int as the second argument to indicate
>> whether the file should be opened with update access, and the
>> SpatialReference.IsGeographic() method returns an int. It would be
>> nice to use a more natural bool in these cases for languages that
>> support it.
>> Would I be right in thinking that there's pretty much no way of
>> changing this now without breaking a lot of code? What about just
>> changing it for some of the newer bindings, e.g. C#, that have
>> recently had breaking API changes applied anyway. I like the new
>> enums, etc for the C# bindings in place of int constants, can we fix
>> the bool vs int problem there as well? I'd be happy to do this if
>> people want to fix it, and Tamas doesn't have time.
>> And while we're changing this, should wkbGeometryType be
>> WkbGeometryType?
>> Cheers,
>> Simon
>> Gdal-dev mailing list
>> Gdal-dev at lists.maptools.org
>> http://lists.maptools.org/mailman/listinfo/gdal-dev
