[Gdal-dev] preferred diff format
Mateusz Loskot mateusz at loskot.net
Tue Apr 3 20:27:12 EDT 2007
Brian Claywell wrote:
> What's the preferred diff format for submitting patches? For example,
>  I'm currently using context diffs with three lines of context, e.g.,
> diff -rc3 /usr/src/gdal-1.4.0/frmts/hfa/ frmts/hfa/ >
> hfa-no-data.patch
If you can generate diff from working copy of GDAL SVN, then
please use 'svn diff' command.
> Are unified diffs preferable? I'm pretty new to submitting patches to
>  large projects.
Personally, when I generate patches with diff from GNU Diffutils,
I use 'diff -Nua' command, but when I apply "manually generated"
patches, I always do it manually.
Cheers
Mateusz Loskot
http://mateusz.loskot.net
