[Gdal-dev] Question on building external overviews
Stephen Woodbridge
woodbri at swoodbridge.com
Wed Apr 4 09:02:06 EDT 2007
Hi guys,
I took this approach to building external overviews, but all my images
seem to be gray in mapserver and appear to be all nodata values in the
file. Any idea what I'm doing wrong here?
I have a directory of of 16x16 tiles that fill a one degree block.
I want to make 4x4 overview files with 4x4 of the original tiles.
ie: 4x4 original tiles into 1 overview
So for the first tile, I create the output tile like this
gdal_translate -of GTiff -co \"TILED=YES\" -outsize 3200 3200 -a_srs
EPSG:4326 -a_nodata 0 -a_ullr $top $left $bot $right $inf $outf
then for each additional tile I mosaic them into $outf like this:
gdalwarp --config GDAL_ONE_BIG_READ ON -srcnodata 0 -rc -wm 150 $inf $outf
Any help would be appreciated.
Thanks,
-Steve
Here is what the $outf looks like:
[swoodbridge at booboo tile-repository]$ gdalinfo OV1/B-100_27/T-100_27-03.tif
Driver: GTiff/GeoTIFF
Size is 3200, 3200
Coordinate System is:
GEOGCS["WGS 84",
DATUM["WGS_1984",
SPHEROID["WGS 84",6378137,298.2572235629972,
AUTHORITY["EPSG","7030"]],
AUTHORITY["EPSG","6326"]],
PRIMEM["Greenwich",0],
UNIT["degree",0.0174532925199433],
AUTHORITY["EPSG","4326"]]
Origin = (28.000000000000000,-100.437500000000000)
Pixel Size = (-0.000078125000000,0.000078125000000)
Metadata:
AREA_OR_POINT=Area
Corner Coordinates:
Upper Left ( 28.000, -100.438) ( 28d 0'0.00"E,100d26'15.00"S)
Lower Left ( 28.000, -100.188) ( 28d 0'0.00"E,100d11'15.00"S)
Upper Right ( 27.750, -100.438) ( 27d45'0.00"E,100d26'15.00"S)
Lower Right ( 27.750, -100.188) ( 27d45'0.00"E,100d11'15.00"S)
Center ( 27.875, -100.312) ( 27d52'30.00"E,100d18'45.00"S)
Band 1 Block=256x256 Type=Byte, ColorInterp=Red
NoData Value=0
Band 2 Block=256x256 Type=Byte, ColorInterp=Green
NoData Value=0
Band 3 Block=256x256 Type=Byte, ColorInterp=Blue
NoData Value=0
