[Gdal-dev] gdalwarp with change in projection for tiles then
adjacent tiles overlap slightly with a black border at edge.
John Mitchell
mitchelljj98 at gmail.com
Thu Apr 5 10:40:48 EDT 2007
I have found that running gdalwarp with a change in projection individually
for each tile and splitting them up via gdal_translate that the adjacent
tiles overlap slightly with a black border at edge. If I instead run
gdalwarp against all the tiles to create a big mosaic with a change in
projection and then split(gdal_translate) them up that I don't have this
overlap.
Is their a way to individually run gdalwarp with a change in projection
against each tile without getting this overlap?
Thanks,
John J. Mitchell
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20070405/ab9c755d/attachment.html
