[Gdal-dev] create 256x256 tiles for google maps
Norman Vine
nhv at cape.com
Sat Apr 7 13:03:10 EDT 2007
Stephen Woodbridge writes:
> Great script, thank you for sharing it.
> You mentioned working with projected coordinates below. I
> would like to do something along the lines gdalsplit, but be
> able to define the height and width on projected coordinates,
> like 0.0625 degrees and have it split the src image into
> tiles that size but the edges aligned to hit 1.0 degree
> intervals. So like 42.0, 42.0625, 42.125, ...
> Is there an easy way to do this in a script?
> Would it be easy to modify gdalsplit to do something like this?
> What if the src image is in some UTM projection and you want
> the tiles in geographic projection?
OSSIM has a couple of command line utilities that do this and more
igen and orthoigen
Docs start at about page 85 of
http://ossim.telascience.org/ossimdata/Documentation/ossim_users_guide.pdf
Ossim has a GDAL plugin so most GDAL supported formats work
Norman
