[Gdal-dev] Where's the _gdal module?
Mateusz Loskot
mateusz at loskot.net
Mon Apr 9 10:12:51 EDT 2007
Roger André wrote:
> I just finished compiling and installing gdal from source in Cygwin. The
> utilities like "gdal_translate" and "gdalinfo" seem to be working fne, but
> I'm, having trouble with the Python API. For example, when I try to run
> "gdal_merge.py", I get the following error:
> $ gdal_merge.py
> Traceback (most recent call last):
> File "/usr/local/bin/gdal_merge.py", line 110, in <module>
> import gdal
> File "/usr/lib/python2.5/site-packages/gdal.py", line 191, in <module>
> import _gdal
> ImportError: No module named _gdal
> When I trace this a bit further online, I see references to needing a "
> gdal.so", but I don't know where it should be, or how to get it.
> Can someone advise me?
Roger,
Could you tell us how did you configured GDAL and what Python bindings do
you want to use: traditional or SWIG-based?
Simply, paste the ./configure command with all options you used.
Cheers
Mateusz Loskot
http://mateusz.loskot.net
