[Gdal-dev] Problem with ogr2ogr and PG
Mateusz Loskot mateusz at loskot.net
Tue Apr 10 18:12:42 EDT 2007
Richard Matsunaga wrote
> I think there is something wrong with the PG driver or ogr2ogr when
> appending or overwriting an existing table.
> I can create a PG table from a shape file just fine, to any schema.
> However, when I try to append or overwrite to the table,
> it will only work if the schema is the default schema in the search path.
Richard,
Yes, you're right there is something wrong.
I've checked the problem and reported as a bug:
http://trac.osgeo.org/gdal/ticket/1572
I'm fixing it after Frank's review.
Cheers
Mateusz Loskot
http://mateusz.loskot.net
