[Gdal-dev] Instructions for Cygwin compile of GDAL
Norman Vine
nhv at cape.com
Thu Apr 12 19:44:08 EDT 2007
Roger André writes:
> Can someone please tell me what file to edit, and what to
> change/add to it, so that I can compile GDAL in Cygwin and
> obtain Python support?
Shouldn't have to change anything
To check I just did a fresh Cygwin install and
./configure --with-libtool=no; make; make install
< might work with libtool I don't know I just can't stand the
glacially slow Cygwin compiles with libtool >
This works for me
Make sure you use Python 2.4 or else you will need to compile
your own Numeric extension module
This was with the latest GDAL source tarball from gdal.org
Cheers
Norman
