[Gdal-dev] HDF MODIS conversion to GeoTiff WGS-84 referenced
format
mattia
mattia.parigiani at gmail.com
Fri Apr 13 09:52:23 EDT 2007
Hey! Thanks a lot, I seem to be getting my Tiff images ok.. Even though they
are all really dark and cant see much out of them.. Is that right anyways??
One more thing I had mentioned in the previous mail is that I need to obtain
also the TWF file that accompanies each TIFF file.. This file specifies
pixel resolution and upper left coordinates of images bounding box.. Does
anyone have a clue on how to obtain this??
For what regards merging the images, I do not have the gdalmerge command...
only the gdalwarp one.. Is this because of my gdal version... Where can I
get the CVS version from? I've been looking for it but was not lucky in my
search..
Can you, or anyone, also help me with the gdalwarp syntax given a series of
.tif files and wanting to merge them into a single viewable one??
Thanks again for your support
Mattia
On 4/13/07, guillaume huby <guillaume.huby.lists at gmail.com> wrote:
> mattia a écrit :
> > Hey all, I really have great confusion on how to convert my HDF 4 images
> > which reside as multiple bands into a single HDF file to a GeoTiff
> > geo-referenced image. In reality, I need to convert the format into a
> > single latitude/longitude *WGS-84* referenced TIFF image..I need to do
> > this and at the same time obtain a .tfw file which specifies the top
> > left corner coordinates of the image's bounding box and the pixel
> > resolution of the image.
> > I've tried to run the gdalinfo command on one of my images.. The image
> > name is AMOD021KM20061229043102.hdf and when I run the command (under
> > Ubuntu) I get the following stack report (the subdatasets are at the
> > bottom part):
> > ---------------------START-LOG--------------
> > rasdaman at mattia-desktop:~/FTPCHINA$ gdalinfo AMOD021KM20061229043102.hdf
> > Driver: HDF4/Hierarchical Data Format Release 4
> > Subdatasets:
> > SUBDATASET_1_NAME=HDF4_SDS:UNKNOWN:" AMOD021KM20061229043102.hdf":0
> > SUBDATASET_1_DESC=[15x3630x1354] EV_1KM_RefSB (16-bit unsigned
> integer)
> > SUBDATASET_2_NAME=HDF4_SDS:UNKNOWN:"AMOD021KM20061229043102.hdf":1
> > SUBDATASET_2_DESC=[15x3630x1354] EV_1KM_RefSB_Uncert_Indexes (8-bit
> > unsigned integer)
> > SUBDATASET_3_NAME=HDF4_SDS:UNKNOWN:"AMOD021KM20061229043102.hdf ":2
> > SUBDATASET_3_DESC=[2x3630x1354] EV_250_Aggr1km_RefSB (16-bit unsigned
> > integer)
> > SUBDATASET_4_NAME=HDF4_SDS:UNKNOWN:" AMOD021KM20061229043102.hdf":3
> > SUBDATASET_4_DESC=[2x3630x1354] EV_250_Aggr1km_RefSB_Uncert_Indexes
> > (8-bit unsigned integer)
> > SUBDATASET_5_NAME=HDF4_SDS:UNKNOWN:"AMOD021KM20061229043102.hdf ":4
> > SUBDATASET_5_DESC=[2x3630x1354] EV_250_Aggr1km_RefSB_Samples_Used
> > SUBDATASET_6_NAME=HDF4_SDS:UNKNOWN:" AMOD021KM20061229043102.hdf":5
> > SUBDATASET_6_DESC=[5x3630x1354] EV_500_Aggr1km_RefSB (16-bit unsigned
> > integer)
> > SUBDATASET_7_NAME=HDF4_SDS:UNKNOWN:"AMOD021KM20061229043102.hdf":6
> > SUBDATASET_7_DESC=[5x3630x1354] EV_500_Aggr1km_RefSB_Uncert_Indexes
> > SUBDATASET_8_NAME=HDF4_SDS:UNKNOWN:" AMOD021KM20061229043102.hdf":7
> > SUBDATASET_8_DESC=[5x3630x1354] EV_500_Aggr1km_RefSB_Samples_Used
> > SUBDATASET_9_NAME=HDF4_SDS:UNKNOWN:" AMOD021KM20061229043102.hdf ":8
> > SUBDATASET_9_DESC=[16x3630x1354] EV_1KM_Emissive (16-bit unsigned
> integer)
> > SUBDATASET_10_NAME=HDF4_SDS:UNKNOWN:"AMOD021KM20061229043102.hdf":9
> > SUBDATASET_10_DESC=[16x3630x1354] EV_1KM_Emissive_Uncert_Indexes
> > SUBDATASET_11_NAME=HDF4_SDS:UNKNOWN:"AMOD021KM20061229043102.hdf":10
> > SUBDATASET_11_DESC=[726x271] Latitude (32-bit floating-point)
> > SUBDATASET_12_NAME=HDF4_SDS:UNKNOWN:" AMOD021KM20061229043102.hdf ":11
> > SUBDATASET_12_DESC=[726x271] Longitude (32-bit floating-point)
> > SUBDATASET_13_NAME=HDF4_SDS:UNKNOWN:"AMOD021KM20061229043102.hdf":12
> > SUBDATASET_13_DESC=[726x271] Height (16-bit integer)
> > SUBDATASET_14_NAME=HDF4_SDS:UNKNOWN:"AMOD021KM20061229043102.hdf":13
> > SUBDATASET_14_DESC=[726x271] SensorZenith (16-bit integer)
> > SUBDATASET_15_NAME=HDF4_SDS:UNKNOWN:"AMOD021KM20061229043102.hdf ":14
> > SUBDATASET_15_DESC=[726x271] SensorAzimuth (16-bit integer)
> > SUBDATASET_16_NAME=HDF4_SDS:UNKNOWN:"AMOD021KM20061229043102.hdf":15
> > SUBDATASET_16_DESC=[726x271] Range (16-bit unsigned integer)
> > SUBDATASET_17_NAME=HDF4_SDS:UNKNOWN:" AMOD021KM20061229043102.hdf":16
> > SUBDATASET_17_DESC=[726x271] SolarZenith (16-bit integer)
> > SUBDATASET_18_NAME=HDF4_SDS:UNKNOWN:"AMOD021KM20061229043102.hdf ":17
> > SUBDATASET_18_DESC=[726x271] SolarAzimuth (16-bit integer)
> > SUBDATASET_19_NAME=HDF4_SDS:UNKNOWN:"AMOD021KM20061229043102.hdf":18
> > SUBDATASET_19_DESC=[726x271] gflags (8-bit unsigned integer)
> > SUBDATASET_20_NAME=HDF4_SDS:UNKNOWN:"AMOD021KM20061229043102.hdf ":19
> > SUBDATASET_20_DESC=[3630x1354] EV_Band26 (16-bit unsigned integer)
> > SUBDATASET_21_NAME=HDF4_SDS:UNKNOWN:"AMOD021KM20061229043102.hdf ":20
> > SUBDATASET_21_DESC=[3630x1354] EV_Band26_Uncert_Indexes (8-bit
> > unsigned integer)
> > SUBDATASET_22_NAME=HDF4_SDS:UNKNOWN:"AMOD021KM20061229043102.hdf":21
> > SUBDATASET_22_DESC=[16x10] Noise in Thermal Detectors (8-bit unsigned
> > integer)
> > SUBDATASET_23_NAME=HDF4_SDS:UNKNOWN:"AMOD021KM20061229043102.hdf ":22
> > SUBDATASET_23_DESC=[16x10] Change in relative responses of thermal
> > detectors (8-bit unsigned integer)
> > SUBDATASET_24_NAME=HDF4_SDS:UNKNOWN:"AMOD021KM20061229043102.hdf":23
> > SUBDATASET_24_DESC=[363x16x10] DC Restore Change for Thermal Bands
> > (8-bit integer)
> > SUBDATASET_25_NAME=HDF4_SDS:UNKNOWN:" AMOD021KM20061229043102.hdf":24
> > SUBDATASET_25_DESC=[363x2x40] DC Restore Change for Reflective 250m
> > Bands (8-bit integer)
> > SUBDATASET_26_NAME=HDF4_SDS:UNKNOWN:" AMOD021KM20061229043102.hdf ":25
> > SUBDATASET_26_DESC=[363x5x20] DC Restore Change for Reflective 500m
> > SUBDATASET_27_NAME=HDF4_SDS:UNKNOWN:"AMOD021KM20061229043102.hdf":26
> > SUBDATASET_27_DESC=[363x15x10] DC Restore Change for Reflective 1km
> > Corner Coordinates:
> > Upper Left ( 0.0, 0.0)
> > Lower Left ( 0.0, 512.0)
> > Upper Right ( 512.0, 0.0)
> > Lower Right ( 512.0, 512.0)
> > Center ( 256.0, 256.0)
> //--------------------------------------------------------------------------END-LOG
> > It looks like the subdatasets could be malformed... This is because I
> > get these SUBDATASET_X_NAME=HDF4_SDS:UNKNOWN: syntax.. is that right..
> > I've been told that the images are MODIS images from Terra and Aqua
> > satellites. I also read that MODIS is used for snow detection only.. is
> > this correct??
> > I'm trying to understand how to achieve what I need and so far I
> > understand that the required commands are the gdal_transform or the
> > gdalwarp commands.
> > When I run gdal_translate on the file, I get the following:
> > rasdaman at mattia-desktop :~/FTPCHINA$ gdal_translate
> > AMOD021KM20061229043102.hdf test.tiff
> > Input file contains subdatasets. Please, select one of them for reading.
> > Hence my question is, how do I tell the command to pick up a certain
> > dataset?? And, where can I find the relative documentation for this
> > command when applied to multiple HDF bands??
> > Finally, I reside in Germany and need to transform a whole lot of images
> > into GeoTiff to later establish a WMS service .. Hence all conversion
> > will need be done remotely... Does anyone have any suggestions on how I
> > should go on about this?? Should I be using the gdal library or would I
> > best bet on something else???
> > Msphinx?? ENVI??
> you should try :
> $ gdal_translate HDF4_SDS:UNKNOWN:"AMOD021KM20061229043102.hdf":0
> test_b0.tif
> $ gdal_translate HDF4_SDS:UNKNOWN:"AMOD021KM20061229043102.hdf":1
> test_b1.tif
> ... and so on for each dataset
> same with gdalwarp.
> this extract only one band. Then you can use gdal_merge or gdalwarp to
> merge bands in a single raster.
> Also have a look to some previous post in the list :
> http://thread.gmane.org/gmane.comp.gis.gdal.devel/10482
> if you meet trouble to get WGS84 correct.
> Good alternates are MRT or HEG modis tools ...
> Good luck !
> Guillaume.
> Gdal-dev mailing list
> Gdal-dev at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/gdal-dev
Mattia
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20070413/449940a5/attachment.html
