[Gdal-dev] GDAL C API and Delphi
mattia
mattia.parigiani at gmail.com
Fri Apr 13 10:34:24 EDT 2007
Would that be under Windows?
On 4/13/07, Frank Warmerdam <warmerdam at pobox.com> wrote:
> Artur Redzko wrote:
> > Hi
> > Is there any special procedure to build GDAL DLL, that can be mapped and
> > used in Delphi through C API. I built DLL using Visual C++ express 2005,
> > tested exports using dumpbin - it looks fine. But when I try to map it
> > in Delphi like :
> > I tested it with daily and gdal 4.1 source with default settings. I also
> > tried to get binaries from vterrain but they also don't work. Strangely
> > found old 1.2 version works.
> > Can anyone help me ? What do I do wrong ?
> > Can someone send me compiled binaries for Windows ?
> > Ps. Sorry for doubled emails. I have problem with my email server.
> Artur,
> GDAL 1.4 should build with most GDAL C API entry points using stdcall
> conventions. I don't know why things aren't working for you, except
> possibly limitations with the express compiler.
> You might want to grab FWTools and try with that GDAL_FW.DLL.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam,
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | President OSGeo, http://osgeo.org
> Gdal-dev mailing list
> Gdal-dev at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/gdal-dev
Mattia
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20070413/613f747e/attachment.html
