[Gdal-dev] HDF MODIS conversion to GeoTiff WGS-84 referenced
format
Vincent Schut
schut at sarvision.nl
Mon Apr 16 02:52:31 EDT 2007
mattia wrote:
> Thanks a lot again,
> Tried to gdal_translate with the -co "TWF=YES" option.... Cant see the
> .twf file though... do I have to tell it where to store it or ?? where
> is it getting stored? any idea?
Possibly because you made a typo :-) It's TFW, not TWF. Using -co
TFW=YES you should get a <filename>.tfw next to your output tiff, right
in the same place.
Cheers,
Vincent.
> Again,
> Mattia
> On 4/13/07, *guillaume huby* <guillaume.huby.lists at gmail.com
> <mailto:guillaume.huby.lists at gmail.com>> wrote:
> On 4/13/07, *mattia* < mattia.parigiani at gmail.com
> <mailto:mattia.parigiani at gmail.com>> wrote:
> Hey! Thanks a lot, I seem to be getting my Tiff images ok..
> Even though they are all really dark and cant see much out of
> them.. Is that right anyways??
> One more thing I had mentioned in the previous mail is that I
> need to obtain also the TWF file that accompanies each TIFF
> file.. This file specifies pixel resolution and upper left
> coordinates of images bounding box.. Does anyone have a clue
> on how to obtain this??
> For what regards merging the images, I do not have the
> gdalmerge command... only the gdalwarp one.. Is this because
> of my gdal version... Where can I get the CVS version from?
> I've been looking for it but was not lucky in my search..
> Can you, or anyone, also help me with the gdalwarp syntax
> given a series of .tif files and wanting to merge them into a
> single viewable one??
> Having a look at http://www.gdal.org/index.html should help you a
> lot to answer your questions ...
> For tfw files, add option -co "TFW=YES".
> Regards,
> Guillaume.
> Mattia
> Gdal-dev mailing list
> Gdal-dev at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/gdal-dev
