[Gdal-dev] OGR C# .NET
Andrew Timmins drewtimmins at gmail.com
Mon Apr 16 17:29:45 EDT 2007
Is there any way you can use the OGR lib in C# .NET ?
I downloaded FWTools and found a /csharp/ directory with a dll called
ogr_csharp.dll
But when I try and use this in a project I get errors.
[Error]
"The type initializer for 'OGR.ogr' threw an exception"
my Code
using System;
using System.Collections.Generic;
using System.ComponentModel;
using System.Data;
using System.Drawing;
using System.Text;
using System.Windows.Forms;
using OGR;
namespace WindowsApplication1
    public partial class Form1 : Form
        public Form1()
            InitializeComponent();
        private void Form1_Load(object sender, EventArgs e)
            ogr.RegisterAll();
If anyone has any ideas please reply.
Thanks,
Drew
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20070416/f252d807/attachment.html
