[Gdal-dev] Proposal for Unified Windows Binaries
Mateusz Loskot mateusz at loskot.net
Tue Apr 17 15:45:39 EDT 2007
Tamas Szekeres wrote:
> Can someone confirm that the usage of the different CRT heaps will not
> cause memory related problems when compiling the code using different
> compiler installations.
Tamas,
I believe no one will confirm that.
> (Is the GDAL C API capable to pass memory
> segments being allocated and released on different sides?)
No, it isn't and it is not recommended practice,
as explained in FAQ #14:
http://www.gdal.org/faq.html
Also, here is more detailed discussion of this subject:
http://support.microsoft.com/kb/q140584/
http://msdn2.microsoft.com/en-us/library/abx4dbyh(VS.80).aspx
> Which default options to use the makefile?
It's not a trivial problem.
Personally, I believe in /MD and embedding manifest in binary.
> There are some further issues should also be considered, like:
> 1. Provide support for WIN64 images
Not trivial but feasible.
> 2. Possible issues related to embedding manifests in a multi-compiler
> environment (VC2003, VC2005)
Yes, that's another kind of DLL Hell.
Cheers
Mateusz Loskot
http://mateusz.loskot.net
