[Gdal-dev] Proposal for Unified Windows Binaries
Joaquim Luis jluis at ualg.pt
Tue Apr 17 17:12:57 EDT 2007
Mateusz Loskot wrote:
>> A test case that I'm working with showed a dramatic reduction in
>> running time using this compiler. from 2 min 50 sec (exe compiled
>> with MSVC6) to 1:50
> It's not a surprise, because Visual C++ 6.0 is a dinosaur and it doesn't
> fit well to modern CPUs regarding optimization.
> Have you tried Visual C++ 8.0 or at least 7.1?
Mateusz,
OK, I tried with 7.1 as well.
The times are now
2:25 min (VC6)
2:05 min (VC7.1)
1:20 min (Intel)
This is with a code that was originally in f77 and that I converted to C
with f2c. I have
been working on it and that's why the times have changed from the
figures I posted earlier.
A side, very irritating, note. With the fortran Intel compiler that same
code takes 1:05 min
> Another subject is that it costs ~400 USD or so :-)
I strong argument indeed.
Cheers
Joaquim
