[Gdal-dev] Proposal for Unified Windows Binaries
Iva Lucena
ivan.lucena at pmldnet.com
Tue Apr 17 19:11:19 EDT 2007
Mateusz, Tamas,
> against GDAL built with Visual C++ 8.0, using official Python 2.4
binaries.
When you say official 2.4 binaries you mean downloaded from python.org:
http://www.python.org/download/releases/2.4.4/ ?
That is great, I almost moving back to VS 2003 just because I can't deliver
GDAL 1.4.1 with Python for people that need it, in the same way I as used to
do with GDAL 1.3.2 in an InnoSetup installation.
Cheers,
Ivan
-----Original Message-----
[mailto:gdal-dev-bounces at lists.maptools.org] On Behalf Of Mateusz Loskot
Sent: Tuesday, April 17, 2007 6:17 PM
To: Christopher Barker
Cc: gdal-dev
Subject: Re: [Gdal-dev] Proposal for Unified Windows Binaries
Christopher Barker wrote:
> Mateusz Loskot wrote:
>> Folks,
>> What compiler should we use to prepare official binaries for
>> Windows?
> The standard Python build (python.org) uses VS2003 (I'm pretty sure),
> so there's a reason to stick with that.
Christopher,
Yes, you're right and that's a very strong argument.
Although, AFAIK recently Tamas has managed to run autotest scripts
against GDAL built with Visual C++ 8.0, using official Python 2.4 binaries.
Cheers
Mateusz Loskot
http://mateusz.loskot.net
Gdal-dev mailing list
Gdal-dev at lists.maptools.org
http://lists.maptools.org/mailman/listinfo/gdal-dev
