[Gdal-dev] GDAL maintenance biweekly report - No. 3
Mateusz Loskot
mateusz at loskot.net
Wed Apr 18 01:50:11 EDT 2007
Here is the 3rd bi-weekly report, it includes only ~6 of 10
work days and the rest of time I was traveling a bit.
== Resolved issues ==
#738 It seems OGR uses reference counting inconsistently,
what result in memory leak
http://trac.osgeo.org/gdal/ticket/738
#755 minixml - can't read complex DOCTYPE elements
http://trac.osgeo.org/gdal/ticket/755
#1412 Schema names are not quoted by OGR tools (ogrinfo/ogr2ogr) when
using PostGIS as datasource
http://trac.osgeo.org/gdal/ticket/1412
#1497 Use EnhancedPrecisionOp? for difference and intersection
operations
http://trac.osgeo.org/gdal/ticket/1497
#1534 OGR GML reader fails if file has UTF-8 BOM prefix
http://trac.osgeo.org/gdal/ticket/1534
#1537 ogr_sql: FID not usable in WHERE clause
#1539 Setup Nightly Snapshots
#1556 Missing recent CPLString improvements in branches/1.4
http://trac.osgeo.org/gdal/ticket/1556
#1566 Proposal of gdalsplit utility
http://trac.osgeo.org/gdal/ticket/1566
#1572 PG incorrectly recognizes layers from non-default schema
http://trac.osgeo.org/gdal/ticket/1572
== Analysed and discussed issues ==
#770 Specify proj4text in spatial_ref_sys table of PostGIS
http://trac.osgeo.org/gdal/ticket/770
#952 Array bounds error
http://trac.osgeo.org/gdal/ticket/952
#976 Wrong OGR2OGR conversion
http://trac.osgeo.org/gdal/ticket/976
#1442 Feature.GetFieldAsInteger? does not behave correctly
on non existant field
http://trac.osgeo.org/gdal/ticket/1442
#1507 GDALRasterIO crashes for width values higher than 2048
with LZW enabled
http://trac.osgeo.org/gdal/ticket/1507
== Other activities ==
* Updated tests:
* minixml.py
* ogr_sql.py
* ogr_gml.py
* fast.py
* hfa.py
* Configured autotest package under Windows with Visual C++ 8.0 builds
and native Python binaries
* Testing beta and stable versions of 1.4.1 release
* Around 60 e-mails to the gdal-dev and around 20 off-list with
support to users
* A few hours on the #gdal channel
* Prepared GDAL binaries on request from Windows users
* New pages on Wiki
* A few tasks about administration of Trac, Buildbot and GDAL website
The whole collection of bi-weekly reports is available on the Wiki:
http://trac.osgeo.org/gdal/wiki/MaintenanceReportsByMateusz2007
Cheers
Mateusz Loskot
http://mateusz.loskot.net
