[Gdal-dev] gdal_translate of HDF : resulting GeoTiff file strange
mattia mattia.parigiani at gmail.com
Thu Apr 19 10:29:21 EDT 2007
Hey all,
I ran the following command on an HDF format:
$ gdal_translate HDF4_SDS:UNKNOWN:"AMOD021KM20061229043102.hdf":9
test_b9.tif
I hence get a geotiff file called test_b9.tif
I actually ran the command on all my 26 channels and got 26 different TIF
files.
I think that this should be the most important channel though, namely, it is
the :
  SUBDATASET_9_NAME=HDF4_SDS:UNKNOWN:"AMOD021KM20061229043102.hdf":8
  SUBDATASET_9_DESC=[16x3630x1354] EV_1KM_Emissive (16-bit unsigned integer)
If I now run gdalinfo I get:
rasdaman at mattia-desktop:~/FTPCHINA$ gdalinfo -nomd test_b8.tif
Driver: GTiff/GeoTIFF
Size is 1354, 3630
Coordinate System is `'
Corner Coordinates:
Upper Left  (    0.0,    0.0)
Lower Left  (    0.0, 3630.0)
Upper Right ( 1354.0,    0.0)
Lower Right ( 1354.0, 3630.0)
Center      (  677.0, 1815.0)
Band 1 Block=1354x3 Type=UInt16, ColorInterp=Gray
Band 2 Block=1354x3 Type=UInt16, ColorInterp=Undefined
Band 3 Block=1354x3 Type=UInt16, ColorInterp=Undefined
Band 4 Block=1354x3 Type=UInt16, ColorInterp=Undefined
Band 5 Block=1354x3 Type=UInt16, ColorInterp=Undefined
Band 6 Block=1354x3 Type=UInt16, ColorInterp=Undefined
Band 7 Block=1354x3 Type=UInt16, ColorInterp=Undefined
Band 8 Block=1354x3 Type=UInt16, ColorInterp=Undefined
Band 9 Block=1354x3 Type=UInt16, ColorInterp=Undefined
Band 10 Block=1354x3 Type=UInt16, ColorInterp=Undefined
Band 11 Block=1354x3 Type=UInt16, ColorInterp=Undefined
Band 12 Block=1354x3 Type=UInt16, ColorInterp=Undefined
Band 13 Block=1354x3 Type=UInt16, ColorInterp=Undefined
Band 14 Block=1354x3 Type=UInt16, ColorInterp=Undefined
Band 15 Block=1354x3 Type=UInt16, ColorInterp=Undefined
Band 16 Block=1354x3 Type=UInt16, ColorInterp=Undefined
Isnt this a strange result?
What about the coordinate system?
I tried to merge all the tifs with gdalwarp, but had no success so far..
I'm pretty new to this field and in very high waters..
Any suggestions?
Thanks
Mattia
Mattia
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20070419/cdb26bcc/attachment.html
