[Gdal-dev] Perl tests
Mateusz Loskot mateusz at loskot.net
Fri Apr 20 14:38:35 EDT 2007
I'm trying to find out why the Perl tests are still failing,
especially for stable branch builder:
http://buildbot.osgeo.org:8500/telascience-stable/builds/8/step-perl-test/0
I tried to run it locally and here is my output:
mloskot:~/dev/gdal/_svn/trunk/gdal/swig/perl$ make generate
mloskot:~/dev/gdal/_svn/trunk/gdal/swig/perl$ make build
mloskot:~/dev/gdal/_svn/trunk/gdal/swig/perl$ make test
make -f Makefile_Geo__GDAL
make[1]: Entering directory
`/home/mloskot/dev/gdal/_svn/trunk/gdal/swig/perl'
make[1]: Leaving directory
make -f Makefile_Geo__GDAL__Const
make -f Makefile_Geo__OGR
make -f Makefile_Geo__OSR
make -f Makefile_Geo__GDAL test
PERL_DL_NONLAZY=1 /usr/bin/perl "-MExtUtils::Command::MM" "-e"
"test_harness(0, 'blib/lib', 'blib/arch')" t/*.t
t/gdal....ok 1/0
Available drivers were AAIGrid, AIG, AirSAR, BMP, BSB, BT, CEOS, CPG,
DIPEx, DOQ1, DOQ2, DTED, EHdr, ELAS, ENVI, ESAT, FAST, FIT, FujiBAS,
GIF, GSAG, GSBG, GSC, GTiff, GXF, HFA, HTTP, IDA, ILWIS, INGR, ISIS2,
JDEM, JPEG, JPEG2000, L1B, LAN, Leveller, MEM, MFF, MFF2, NDF, NITF,
PAux, PCIDSK, PCRaster, PDS, PNG, PNM, RIK, RMF, RS2, RST, SAR_CEOS,
SDTS, SGI, USGSDEM, VRT, WCS, XPM
Drivers used in tests were: GTiff, MEM, EHdr
t/gdal....ok
t/ogr.....ok 1/0
Available drivers were AVCBin, CSV, DGN, ESRI Shapefile, GML, KML,
MapInfo File, Memory, OCI, ODBC, PGeo, PostgreSQL, REC, S57, SDTS,
TIGER, UK .NTF, VRT
Drivers used in tests were: ESRI Shapefile, MapInfo File, Memory
t/ogr.....ok
All tests successful.
Files=2, Tests=673,  1 wallclock secs ( 0.51 cusr +  0.07 csys =  0.58 CPU)
Why I'm getting such short output and the stable builder prints out much
longer status?
Is there anything I've forgot about?
Cheers
Mateusz Loskot
http://mateusz.loskot.net
