[Gdal-dev] wcs tests failing
Mateusz Loskot
mateusz at loskot.net
Mon Apr 23 07:36:45 EDT 2007
Ivan notified me that wcs tests are failing due to some strange problems.
It seemed to me that there is not enough space or may be /tmp on
xblade14-2 or geodata.telascience.org is not writable but this is not
the case here.
Frank,
Could you check what's going on here?
Running tests from gdrivers/wcs.py
TEST: wcs_1 ... success
TEST: wcs_2 ... ERROR 1: msSaveImageGDAL(): General error message.
Failed to create output GTiff file.
TIFFOpen:/tmp/srtmsrvr/462c9826_5da1_0.tif: No such file or directory
fail
open failed.
TEST: wcs_3 ... skip
TEST: wcs_4 ... skip
TEST: wcs_5 ... ERROR 1: msSaveImageGDAL(): General error message.
TIFFOpen:/tmp/srtmsrvr/462c9827_5da3_0.tif: No such file or directory
Cheers
Mateusz Loskot
http://mateusz.loskot.net
