[Gdal-dev] GDAL C# bindings exception: Attempted to read or write
protected memory
Tamas Szekeres
szekerest at gmail.com
Tue Apr 24 06:36:51 EDT 2007
Ben,
If you would like to use the gdal1.4 branch as the gdal core and only
aware of the C# interface of the SWIG bindings, then checkout:
http://svn.osgeo.org/gdal/branches/1.4/gdal/
and replace the the swig directory with the files from the SVN trunk.
Then you can compile gdal and gdal C# as usual.
Best regards,
Tamas
2007/4/24, Ben Greene <bgreene at rapidmap.com.au>:
> Tamas,
> Would the SVN trunk be considered stable enough to release with a commercial product? If it's probably not a good idea, is there currently a target date for a stable release based on this new code?
> Thanks
> -----Original Message-----
> From: Tamas Szekeres [mailto:szekerest at gmail.com]
> Sent: Mon 4/23/2007 8:29 PM
> To: Ben Greene
> Cc: gdal-dev at lists.maptools.org
> Subject: Re: [Gdal-dev] GDAL C# bindings exception: Attempted to read or write protected memory
> Ben,
> I would suggest to start with the latest SVN trunk. There were some
> fundamental changes compared with the current stable branch. It might
> be more difficult to make this transition later. For more information
> see:
> http://trac.osgeo.org/gdal/wiki/GdalOgrCsharpVersions
> http://trac.osgeo.org/gdal/wiki/GdalOgrInCsharp
> Best regards,
> Tamas
> 2007/4/23, Ben Greene <bgreene at rapidmap.com.au>:
> > Hi,
> > I had a problem with the GDAL C# bindings freezing a little while ago, and Tamas managed to find the problem (I was passing in a two-element array instead of a three element for the return value). However, now I'm having a different issue.
> > I'm working with 1.4.1 binaries compiled myself according to the instructions on this site (I can't find the most recent binaries in the FWTools distribution). When I run the code below, I get a System.AccessViolationException:Attempted to read or write protected memory exception on the line:
> > transform.TransformPoint(point, px, py, 0.0)
> > It appears that the exception is thrown from this line:
> > public void TransformPoint(double[] argout, double x, double y, double z) {
> > osrPINVOKE.CoordinateTransformation_TransformPoint__SWIG_1(swigCPtr, argout, x, y, z);
> > The test image I'm using is:
> > o41078a5.tif
> > from
> > http://dl.maptools.org/dl/geotiff/samples/usgs/
> > Here is the VB.Net code I'm using (in VS 2005):
> > Imports GDAL
> > Imports OGR
> > Public Class GeoTiffReader
> > Private Shared image As Dataset
> > Public Shared Function GetGeoReference(ByVal Filename As String) As GeoReference
> > If Not (Filename Is Nothing) Then
> > 'Return Nothing
> > 'if uncommented, the code will not crash
> > End If
> > GDAL.gdal.AllRegister()
> > image = GDAL.gdal.Open(Filename, 0)
> > If (image Is Nothing) Then
> > Return Nothing
> > End If
> > Dim gr(6) As Double
> > image.GetGeoTransform(gr)
> > Dim topLeft() As Double = TransformWGS84(gr(0), gr(3))
> > Dim bottomRight() As Double = TransformWGS84(gr(0) + gr(1) * image.RasterXSize, gr(3) + gr(5) * image.RasterXSize)
> > If (topLeft.Length = 2 And bottomRight.Length = 2) Then
> > Return New GeoReference(topLeft(0), topLeft(1), bottomRight(0), bottomRight(1))
> > Else
> > Return Nothing
> > End If
> > image.Dispose()
> > End Function
> > Public Shared Function TransformWGS84(ByVal px As Double, ByVal py As Double) As Double()
> > Dim point() As Double
> > point = New Double() {0.0, 0.0, 0.0}
> > Dim srWGS84 As New SpatialReference("")
> > srWGS84.SetWellKnownGeogCS("WGS84")
> > If (image.GetProjection() = "") Then
> > Return New Double() {}
> > End If
> > Dim srCurrent As New SpatialReference(image.GetProjection())
> > Dim transform As New CoordinateTransformation(srCurrent, srWGS84)
> > If (transform Is Nothing) Then
> > End If
> > Try
> > Catch
> > End Try
> > Return point
> > End Function
> > End Class
> > Gdal-dev mailing list
> > Gdal-dev at lists.maptools.org
> > http://lists.maptools.org/mailman/listinfo/gdal-dev
