[Gdal-dev] ogr2ogr hundreds of shapefiles
Howard Butler
hobu.inc at gmail.com
Thu Apr 26 10:26:20 EDT 2007
Here's a bash script that I use to bulk load a directory of
shapefiles that have the same schema to postgis. It could obviously
be made smarter, but it seems to do the trick.
#!/bin/bash
# let OGR create a table from one of the files
ogr2ogr -f Postgresql PG:"host=smoke.hobu.net" -a_srs "EPSG:26915" -
nln outputlayer first_input_shape.shp -overwrite -nlt POLYGON
# delete all the data in the table we just created (but don't delete
the table)
ogrinfo PG:"host=smoke.hobu.net" -sql "delete from outputlayer"
# loop through all of the shapefiles in the directory and load them
for i in $(ls *.shp); do
ogr2ogr -f Postgresql PG:"host=smoke.hobu.net" -a_srs " EPSG:
26915" -nln outputlayer $i -update -append -skipfailures
done
On Apr 26, 2007, at 9:05 AM, Martel, Christian wrote:
> Hi List,
> How can I merge hundreds of shapefiles with wildcard in input name
> (eg.
> fileABC*.shp) ? Does ogr2ogr allow this ?
> Is it better to write a python script (opening each file, reading
> geometries, write them to output file, etc.) ?
> Thanks,
> Christian
> Gdal-dev mailing list
> Gdal-dev at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/gdal-dev
