[Gdal-dev] Re: [FWTools] org2org: import TIGER data into a specific schema in PostgreSQL
Marvin delphet at excite.com
Wed Aug 1 11:40:52 EDT 2007
Hi, Tim,
It worked. Thank you so much. BTW, was it mentioned in any documentation?
 --- On Tue 07/31, Tim Keitt < tkeitt at gmail.com > wrote:
To: gdal-dev at lists.maptools.org
Date: Tue, 31 Jul 2007 23:35:00 +0000 (UTC)
Subject: [Gdal-dev] Re: [FWTools] org2org: import TIGER data into a	specific	schema in PostgreSQL
Marvin <delphet <at> excite.com> writes:> But it still put the data into the "public" schema. Could anyone please giveany suggestion? Thanks.Yes. I was just doing that 5 minutes ago.Use the -lco option eg -lco SCHEMA=<schema-name>One catch though -- only lowercase schema names are accepted!THK> > _______________________________________________> Join Excite! - http://www.excite.com> The most personalized portal on the Web!> _______________________________________________Gdal-dev mailing listGdal-dev at lists.maptools.orghttp://lists.maptools.org/mailman/listinfo/gdal-dev
