[Gdal-dev] Re: gdal_translsate color problem
Suray Ph philippe.suray at market-ip.com
Thu Aug 2 12:07:48 EDT 2007
Frank,
Thank you for this response, this OK now.
But if i add ... -co INTERLEAVE=TRUE TFW=TRUE ..., the output is also wrong!!
The result image is grey.
Could you give me an explanation?
Thank you.
Philippe.
