[Gdal-dev] Re: gdal_translsate color problem
Suray Ph philippe.suray at market-ip.com
Fri Aug 3 09:51:29 EDT 2007
Suray Ph <philippe.suray <at> market-ip.com> writes:
> Frank,
> Thank you for your help, you can download the files at:
> http://dev.market-ip.com/B250048_P72_Y2005_S68.tif
> http://dev.market-ip.com/out.tif
> I used this command line:
> gdal_translate -of GTiff -co "TFW=TRUE INTERLEAVE=PIXEL"
> B250048_P72_Y2005_S68.tif out.tif
> Hope this can help to point the problem.
> Regards.
> Philippe
Frank,
I think i found the problem. I open out.tif with this stupid MS Office Document
Imaging, if i open this file with OpenEV, everything is right.
Apologize for this question, thank you for your help.
Philippe.
